Missing
Heavy_d1983
I woke up one morning to a dead battery. Found that the alternator was the culprit and changed it out. After the fix, my 4.6L has a miss. So I have checked all the obvious causes. The wires are about a year old, plugs are about a year and a half. Not sure on the coil packs. The miss is intermittent until it warms up then it's constant. It smooths out when the motor is kept above 1500-1700 rpm, once the throttle is released it goes right back to missing. Please help!!!!! I really don't want to just start throwing money at it.
H
Heavy_d1983
1998, 252k, don't know what "MIL" is, and no I have not. Beginning to think someone pulled the bulb from the "check engine" light. It's nowhere to be found on the dash on start up.
BAD RONALD
Fairfield CT
MIL= Malfunction Indicator Lamp. It's the same as CEL (Check Engine Light).
Have the codes read, write them down and reference them.
YoungKraze
CHICAGO IL
check the codes at your nearest autozone ! i am begining to think your transmission might be slipping or your torque converter is going bad
H
Heavy_d1983
I figured it out. Talked to a couple people experienced with 4.6L's. It was a loose spark plug.
