Multiple Electrical Issues (GEM??)
NeverBRich
PEI
First off I am sorry if this is posted somewhere else. Been reading for hours on here in the last couple of weeks, to no avail.
So, the History. Bought a 1997 expy EB 5.4L around 5 yrs ago. I drove it for 2 yrs, It got an Exhaust leak, Manifold stud, etc etc. around same time rear controls for heater/AC stop working, as well as the factory radio. So I parked it outside for a year. then moved it inside for the last 2 yrs. Finally Saved a couple of dollars, ordered exhaust manifolds. Put everything back on. Fired it up. First click of key and it started. on to Rear Control panel/Actuator/blower.
Opened door all interior lights started flashing, started the truck they stopped. Power Locks, power Windows, radio and rear heat/AC now not working and I have flashing Interior lights to boot.
All symptoms except the flashing lights remain when started.
I have checked all the fuses, diodes, and relays, test light, Multi-meter, and battery.
Running out of Ideas.
Read somewhere that it could be the GEM. Also read on here to Stop attacking the fuse/GEM and tackle the individual problems.
Any guidance, schematics, suggestions would be appreciated.
forgot yes I do live above the 49th parallel so Snow, Rust, rain, and salt is all here.
(P.S. wife is threatening to send a shotgun shell and throw a match into it. I really like the Beast. Would hate to see it go up in flames)
Temple, Georgia
Welcome to the site.
One main indication of issues with the GEM is a wet driver side floorboard or fuse box. What is the status of yours?
NeverBRich
NeverBRich
PEI
The floorboard appears dry, carpet has no stains, the fuses and connectors appear fine, as in no corrosion or rust.
NeverBRich
NeverBRich
PEI
OK upon testing all the LT Blue/Red I am getting a ground reading on all of them, According to the Schematic they should be live. So this Points in the direction of a bad Ground(s) or a short.
Any ideas on where to start hunting. all the obvious grounds(aka Blk wires are testing ground as well)
Temple, Georgia
Depends on how you tested them. They do have a path to ground through each bulb.
Shorts on this circuit will usually blow fuses.
First step is to read source voltage at the battery posts (not clamps).
NeverBRich
NeverBRich
PEI
By unplugging the plugs and back probing the plugs. Tested it with 2 types of test lights, one that is powered and shows ground or pos, and with the older version that has to be connected to either ground, or a Pos. I will Test it with the Multi-meter tomorrow
NeverBRich
NeverBRich
PEI
Ok so Voltages.
Battery -------- 11.8v
Power Dis.t Box fuse 7 --- 11.7v
Tan/white Wire at Main Light Sw. ---11.7v
Blk./red at main light switch ---- 0v
junction fuse box fuse 18 ---- 4.6v
Dark blue/white ------- 4.6v
light blue/red
LF window --- 3.8v
LF door lock --- 3.2v
RT window --- 3.8v
RT door lock --- 3.2v
RT rear window --- 3.8v
LF rear window --- 3.8v
4wd mode switch --- 4.1v
function select sw. --- 7.3v
instrument panel --- 8v
rear control panel --- 0v checked with a live and got 7.3v so it is reading as a ground
rear defrost --- 0v " " "
LF rear vent Works
RT rear vent Works
front Blower Works
Rear Blower --- 0v (does not work) " " " "
Radio-----radio lights up, cd plays, no radio signal.
Anything else that you could lead me to test?
Or point me in a direction to check?
thanks for your time and help.
Temple, Georgia
One thing I hammer into our students is always check your source voltage before troubleshooting an electrical problem so that you know the state of charge of the battery bank to avoid chasing g your tail. In your case the system voltage is way too low:
Open Circuit Voltage at the battery
100% = 12.6v
75% = 12.4v
50% = 12.2v
25% = 12.0v
dead =11.8 and lower
Your reading of 11.8v means the electrolyte activity is so low the battery can't do very much other than run some light electrical loads. If you have a battery charger I would charge it back to 100% then start troubleshooting.
Are all lights pulsing or just specific sets?
NeverBRich
NeverBRich
PEI
update, fully charged battery, Interior dome lights, and interior courtesy lights flashing whenever I open the door. If I turn the interior lights on via switch they stay on with no flashing. dash lights seem fine. Power windows/door locks still do not work, rear heater/AC still is a no go. Going to test the voltages tonight or tomorrow night. will update when I have them. Is there something in particular that I am looking for, to indicate the GEM may be the issue?
NeverBRich
NeverBRich
PEI
Thank you, starting to rule out GEM Found Blinking light prob. Faulty Ground, upon testing the issue it corrected my power door locks. Still no rear blower or power windows....but it is a start. Still going to test voltages as soon as I get a chance.
NeverBRich
NeverBRich
PEI
All problems solved. The power Windows was a faulty Relay. The Power locks and Flashing interior lights was a Ground wire corroded off. and the rear Blower was the Pink/white wire broken somewhere between the front and rear door. All fixed, thanks for the diagrams and help!! It is very appreciated.
