Navigator headlights
G
Guest
Guest
Will the Navigator Xenon headlights work in 2003 Expi Eddie Bauer?
G
Guest
Guest
You'd be better off just upgrading to an aftermarket plug in kit. They run about $200-500 to do the low beams and will be brighter if you use the 8000K set up. I've done it and it takes about 30mins. to install as direct plug ins to the factory wiring with the ballasts. The high beams are fine as they are only that they will look very 'orange' after the HID upgrade.
G
Guest
Guest
From a local shop, but they have them on a variety of on-line catalogs including www.performanceproducts.com The other nice thing is that not only are they brighter but they are less demand on the alternator.
