Need help for the interior light bulb size!
cooleric2000
usa
I am thinking about having all my car interior map lights, dome lights, step courtesy lights changed to White LEDs.
I have checked the Osram Guide but still a little bit confused about the bulb sizes I need. Can someone who has did this help me out, thanks a bunch!
Tuffy
Tampa/Auburn
I know I probably should, but I hate the color red. The only reason my expedition is red is because it was my moms car and she has to have a red car (lucky for her...she upgraded to a red Porsche) so I reallyyyyyyyy don't want to do red
EDIT: That place only had the white lights (unless I am just dumb) where can I get colored lights? or if someone knew the size I could probably just find them
ELVATO
Orlando, FL
Shhh, don't let her hear you :D
You can get LEDs off of ebay. There's this one seller who I use whose pretty good. I've had the LEDs for while, and they're still going.
Tuffy
Tampa/Auburn
Could you hook us up with a link?
ELVATO
Orlando, FL
http://stores.ebay.com/wardenjp2002
Where I got my plate lights:
The ones in the picture are the 1W 194s, but I also had the 4 wide angle ones, and they are almost as bright, for a bit cheaper. Not sure how the tail light bulb is set up on the older Expys, but on the 03-06, it is a clear done that fires downward, which lets a lot of light out.
I know on the F150s and Superdutys, it's a black dome with a slit that lets light out, so the plate lights won't be nearly as bright.
riccoh
honolulu, hi
try autolumination.com.. for lights that has been the site i been using for a while (motorcycle lights and such) and I got the blue 194's for the dash and ac controls and i'm waiting on a set of #78's to finish the instrument panel, and just found out you can use the 194s on the running boards as well,
they even have a single 194 bulb that changes to 7 diferent colors by it self..
