Need help guys!
AbelNavyvet
Weslaco
on my 2nd Gen Expo my heater hose assembly started to leak from the T-connector and this leak ended up on Cylinder 1 coil making it go bad. to better assist you guys to what I'm asking here is the part number 05-06 Expedition Navigator 5L1Z18472AC KH-711 you guys can Google it. has anyone ever changed this part out? is it difficult or should I take it to a professional? where do the 3 different hoses go to? please help guys!
stamp11127
Temple, Georgia
If you want the stock look you'll need to replace the hose. RockAuto should have it listed in their catalog but they are pricey and you will need the "not so quick disconnect tool" to release them, if they still employ that nonsense on the hoses.
TechRN31
Englewood, FL
If you do go ahead and replace this yourself, make sure you know how to bleed your coolant system of air. If you don't, then take it to a professional.
AbelNavyvet
AbelNavyvet
Weslaco
is there a YouTube video showing you how to bleed the coolant syst.
TechRN31
Englewood, FL
I'm sure there is. You tube has everything. Just make sure you find the video first before attempting it
