Need help on a 97 expy
dustrag73
My expy started having a slight vibration at 60mph. I dropped the drive shaft and noticed the bronze bushing in the trans/ transfercase stuck on the drive shaft yolk. Whats involved in repairing this? Its the rear driveshaft and my expy 4wd
1955moose
When did the vibration start? Are you feeling it through steering wheel? Is their anything you or mechanic did to start problem. Read vibration at 70mph. In other post here. When was last tune up? Plugs, cop wires? Any dtc codes with scanner?
docraymund
philippines
You should remove the stuck bushing from the yoke using a suitable puller. Install a new one after. That's the one causing the vibration -coming from driveshaft imbalance.
