The trans is separated and the old converter is draining in a pan for core return. I compared all the flexplate to converter studs and they all seem equally spaced, so no unique orientation as far as I could tell.
What helped me get to this point was pulling both sides of the exhaust downpipes, the trans x member, the heat shields and dropping the trans down at an angle to get to the upper engine to trans bolts. I dropped the trans pan to get at the cooler line connections only to notice that they're a press-fit using 2 o-rings to seal to the case. Just remove the securing bracket then pry hard at the connections and they'll wriggle out.
At this point, getting it back together looks twice as hard, honestly.
