Need help with heat
Firepuppy
Rome NY
i have a 2002 expo and when im at idle the truck blows cold air only when i drive down road does it blow warm air not hot but warm i just changed thermostat today still the same i was told it was the water pump getting weak and not pushing enough water until under power is this possible
thanks
walnuts4x4
Watertown, NY
+1 for blend door... Very common problem
Back when I had my expy had this problem... I removed glove box and cut into the "box" that holds the blend door and I just taped the blend door to either hot or cold depending on season... Then sealed the door by using the heat tape that's used for household heating the aluminum tape... I only cut 3 sides and bent it up.... Ghetto, yes... But worked for me until I traded it in 3 years later...lol
rtbrjason
Rochester, NY
If it's warm while driving and cold while idling it's likely not the blend door. I think your heater core is partially plugged. You can disconnect the hoses and try blowing it out with a hose and/or some compressed air.
