Need help
MartinP
Chesapeake
I have a 03 exp. and it is running fine while driving but as soon as I stop at a red light the truck feels like it going to cut off. I put a scanner on it and it told me to change the o2 sensors and I did. Also changed the PVC valve and some hoses. Any help would help out a lot. Just don't want to keep change parts for no reasons. Thanks
B
bedrck46
have you checked for ant new codes since changing the O2 sensors and what was the code you had?
Canadianguy
Ontario
So it's still got the same symptoms since you've changed the o2 and Pcv? When was the fuel filter changed last?
