Dark_knight
vehicle: 1999 expedition xlt 4.6l (triton) 4x2
This issue has been going on for about 5 months now...
on start-up from cold start, you can hear a whinning noise (slight) until engine idle settles (about 2 sec.)
when driving, the whinning is constant and gets louder the harder the gas is pressed. when cruising highway, there is a constant whine, again the more gas, the louder it gets. when coasting (off throtle) the whinning seems to go away.
recently i have put the truck in nuetral and rev. when i do this, this whining is gone, even while reving, but as soon as i put in drive, the noise is there.
What i have checked:
tranny fluid level is perfect (could use flush and filter) will be doing this within the month
power steering fluid on mid mark(between min/max)
sprayed penetrating lube on each pulley with no luck.
i havnt went into to much work with it as it has been the spare vehicle, but i am leaning towards "power steering moan"..
hopefully someone has ran across this problem and has found the solution before i start diagnosing....
