New Rear Wiper Rotates Once then Stops
ramjet69
Montana
Hello,
I have a "new to me" 2012 Expy LTD and the rear wiper and spitter wasn't working. The transmission was seized and had burned out the motor. I replaced the motor and the transmission and the new motor now rotates once then stops. I can hear the intermittent click (I assume from the relay) but the motor / transmission does not rotate. If I open the rear lift glass then close the glass it "resets" and the wiper will rotate one time again and then just the "relay click" with no wiper rotation.
I can replace the rear glass latch but I don't want to just part swap. Any ideas what may be going on?
TIA
Motorcity muscle
Motorcity
Welcome to site. Going to need to get a volt meter and check if motor is getting power. Can try switching relays with another one next to it. Does the control knob on turn signal arm operate correctly?
R
ramjet69
Montana
I'll test with voltmeter this afternoon but I do believe the control knob works properly as it will turn on and the rear spitter works now anytime I want it.
r98exp1
