No Oil Presure Upon Cold Startup
outkast
Caseyville, Il (near STL)
I just got my 2000 5.4l expy and upon cold starts (15-25 degrees) my expy has no oil pressure. If you bump the throttle, it quickly jumps to 2 clicks above half and stays there for 5-6 seconds until it drops back to 0. it won't slow drop either, just goes from full pressure to nothing.
This morning I let it Idle for 8 minutes, which is when it all of a sudden got pressure back...never heard a tick or knock. I'm going to assume, its a bad sending unit, since 8 minutes on a cold start should have been plenty of time to hear rockers tapping or somthing....right?
I found one thread after searching about a chaffing wire on the drip chute, but my wire runs along the side of the oil filter, so I don't think that is it.
Anyone else get this?
O
outkast
Since I just got it Saturday, I can only go by what is on the window sticker which is 5w30 maxlife from valvoline. It will be getting changed today when I get off work..oh yeah truck has 118k on it.
what weight do you reccomend?
Remo
Hartford, CT
I have also had this problem for a couple of years with my 2000 5.4.
I think it is pretty common and it is generally the sending unit, from what I have heard.
I never fixed it, however, so I can't be certain, but I do know my truck has been running just fine with no problems.
O
outkast
hmmm...well tomorrow is my dedicated "work on cars day" (this happens when you own two fords lol) I think I will put a sensor on it after replacing the coils on my LS.
