nobody knows the trouble I've....
mmrseed
Huntsville
uggh. Two different shops have been unable to diagnose why my '99 expy has a tranny dtc that won't go away and my expy keeps stalling when I put it in reverse or at idle. Also the OD light on the shifter flashes incessantly. I read where someone on here has a similar problem but not close enough to consider it the same problem....any ideas?
ELVATO
Orlando, FL
Have you gone to a transmission shop or the dealer (I'd try the transmission place first)? Did the places you took it to have scanners that can read transmission codes?
Also, I keep reading of people just disconnecting their batteries to "clear" the code. For some, it clears it and never comes back. If it's a recurring problem, though, it will come back.
mmrseed
mmrseed
Huntsville
yeah, one of them was a trans shop, the other was just a general purpose repair shop. Both got the trouble codes but apparently it isn't specific enough to direct attention to the source of the problem. They changed some reverse switch and that didn't do it and now they are telling me to take it to an electrical specialist to maybe get a new computer.....I want a car with a carburator at this point.
Stoned06
Milwaukee
I have heard the OD light flashing can be a sign that the trans is about to take a dump, or it can also be a switch or solenoid that needs replacing. I would have the dealer diagnose it, and if it is something you can do, just do the repair yourself.
ELVATO
Orlando, FL
Only thing that sucks is that it's usually like 60-70 for the dealer to diagnose something. Did the shops give you a code?
tritonman5.4
brooklyn ny
yea dude that was me,my OD light was flashing on and off,and recently my truck has been stalling and cutting right back on,mostly in drive,when i took my truck to ford to get the OD light situation tooking care of,they told me i had line pressure issues what ever they did,it worked it hasn't came back on since.how ever they told me they couldn't fix my selonoid problem
trdragons44
nj
my 97 had the od light flashing and took it to a tranny shop and found out my trans blew overdrive and 3rd gear drum. but mine was banging as it was shifting. and do u know what the dtc was?
mmrseed
mmrseed
Huntsville
I feel stupid because I can't find the paper now that i wrote the dtc's on. I get my truck back tomorrow and then I'll know, but by then I'll also have it on the way to an electric specialist to look at the computer....my truck never used to break down at all but now it does and it never goes easy I tells ya.....
mmrseed
mmrseed
Huntsville
well....just an update. Ford has had the expy a week now and they can't figure out or isolate the problem either
2blackfordrides
POULSBO,WA
Just wondering if u have a update on this..... I just changed my trans and now my truck stalls in reverse.... Thanks in advance for ne info.....
soda
Ca.
Had the same problem with reverse after tranny swap. Forgot to plug in speedometer sensor.
