Noise
EbonLinctus
2001 Expedition XLT 5.4L V8
Near the rear wheel on the driver's side, there is a noise similar to the tone of Emergency Broadcast System that seems to sound off whenever we use the AC. It continues for a moment after turning off the vehicle.
Any idea of the cause?
JUST4FUN
Admin
Moderator Administrator
Il
do you have rear air? This is where the rear air is housed
could be the orfice tube block is going bad take it to an a/c guy
and have them conferm this
E
EbonLinctus
I noticed last weekend that the noise happens when not using the AC.
My wife went to see a Ford mechanic. He mentioned something about the evap system.
green03
College Station, TX
yes the evap canistor is back there somewhere. If the solonoid under the hood fails it will pull a really hard vacuum on the fuel tank. Also when it is happening stop and see if the gas cap is the source of the noise... sometimes the cap has a small leak so it will make noise from the vacuum in the system..
Matt R
