Normal sounds? 5.4 3V new to me.
Bill Schmidt
Omaha, NE
What are normal 5.4 3V sounds?
So 2010 Ford Expedition (doy that why posting in this forum)
187K miles and the oil definitely was not changed every 3 to 5k ... more like 10K ish from what I can tell.
I've been researching this and seems lots of potential problems around phasors, timing chain tensioners, and valve rockers.
I've seen a few YT vids which try to record the sounds but frankly I don't think the full range of audio is coming through to discern what they are listening to.
Anyone know of a reference which what a "normal" 5.4 3V should sound like then compare to the above noted problems and the sound indication of what to listen to to identify which might be wrong?
Does that make sense?
I'm paranoid that I've bought a lemon after seeing everyones problems... but it drives great and inside interior cant hear anything weird.
Trainmaster
Old School Member
Rockaway Beach, NY
The only unusual sound from a well running 5.4 would be a "light" ticking from the fuel injectors which is normally only heard next to the engine and barely heard with the hood closed. Just my opinion, and I've owned several. Here's what I've learned:
Worn chain guides or leaking tensioners "rattle" for a several seconds at startup. Phasors can sound like a diesel engine clammoring. Worn rockers make loud tapping like bad lifters on a pushrod engine.
Anyone agree or disagree?
(I would use the semi or full synthetic oil recommended by Ford and only Ford Motorcraft oil filters which are $3 at Walmart. They have a silicone anti-drain down valve in them that keeps oil up in the top end of the engine at start-up.)
Bill Schmidt
Bill Schmidt
Omaha, NE
So I just went out and recorded the cold engine idle and how it sounds ... this might make it easier for someone experienced to hear it instead of me trying to figure it out.
762mm
Quebec, Canada
My 2014 sounds very much like it, although the ticking is a lot less pronounced (it may be your camera mic that is very sensitive, though).
I just bought my truck too though and the dealer who sold it said engine was 100% in great condition and well maintained. The previous owners (a police dept) also confirmed that the truck was always taken care of and maintained at regular service intervals.
130,000 miles on mine.
P.S. I switched mine to synthetic oil for these reasons. I've put 4 quarts of 5W30 and 2.5 quarts of 5W20 to get it started, plus a FRAM ultra synthetic oil filter (the only FRAM filter worth using - the rest are crap).
In the future, I will switch it over to 5W30 exclusively. According to Ford Tech Makuloco on YouTube, these 5.4L V8 engines are spec'd for 5W30 everywhere else other than North America and don't have these common chain / phaser issues. Our trucks are 5W20 in America because of stupid anti-pollution CAFE standards.
Bill Schmidt
Bill Schmidt
Omaha, NE
I think the ticking sound is stronger now that I've changed the oil. (used 5w-20, some say 5w-30 is way to go???) after I got it the a/c compressor clutch was shot so I replaced it first... then the dip stick was stuck and read that many people say the engine has to be hot ... still stuck but better ... slowly worked it free to find that the oil level was only on the tip of the dip stick and very very black. So changed the oil and air filter ... air filter was nasty: IMG_20190903_223042.jpg
762mm
Quebec, Canada
Holy crap, man! Whoever owned this truck before you deserves a punch in the head, lol... what a shame.
I plan on taking mine to an acquaintance of mine who works on these trucks all the time at Ford, just for the peace of mind. I'll let him listen to it and give me his professional opinion. It is said that if you address the timing / phaser issues early (if you have them), then you can make the engine run for another few hundred thousand miles without issues.
Addressing the problem before it irreversibly damages the engine is much more economical than putting in a new engine, by the way.
Engine sounds fine. Use 5W-30, better for the engine I won’t go into why as it’s been beaten to death. Maybe light noise from passenger valve cover, which is the last on the oil feed.....5W-30 helps. It is not dieseling or running rough and sounds ok.
These are loud engines up top, overhead cam and loud injectors. Phaser issues are the main symptom of problems, that is mainly heard under the truck and is more of a loud knock type sound. From there timing codes would be set off if it went unchecked.
Bill Schmidt
Bill Schmidt
Omaha, NE
I've read a lot about the 5W30 Europe versus US makes sense to me I think I'll do it right away seeing who knows how long it's been since this had an oil change before I did it
coolzzy
Idaho
My 2010 F150 with the 5.4 was quiet as a church mouse and smooth as butter at idle when I traded it in at 55k miles. My 05 F150 on the other hand rattled when cold started and sound like a very quiet diesel at hot idle but still ran great. I always used 5w30 penzoil pure platinum + in the 10 which I owned for 20k miles. The older 05 I purchased with 100k miles and sounded the same after 15k miles of use and religious 3k mile oil changes. Some of these motor are louder than others but treat them right and they will return the favor.
TDGFordGuy
Bay Area, CA
I went from the recommended Motorcraft 5w20 to 5w30 Full Syth Mobil 1 in my 2013 Taurus (150k miles). I figured since the SHO has the same motor and is recommend 5w30 it won't hurt... all extra clacking gone and improved mileage. Go figure. Also stopped getting the $3 Ford branded oil filter and now switched to WIX Xp filters. There's several videos on youtube showing the build quality. Still found rust on one at Kragen (looks to have been a return or on the shelf a LONG time). Made the switch in my Expy; but it's at the insurance shop cause the oil change shop messed with my transmission.
richs fishes
Long Island, NY
I get what I guess I would call "ticking" for a few seconds at startup but only when cold. Sort of also sounds a bit like a diesel. I initially thought this was possibly a bad exhaust manifold and/or gasket as it kind of sounds like an exhaust leak but now I'm thinking its either the tensioner or the phasers or maybe both. Either way my noises seem to disappear once the engine is warmed up.
Phasers get louder when warm and the oil heats up if that’s an issue. It’s possible you have a manifold leak, I had both of mine replaced this spring because of ticking and noises when cold which was because of snapped manifold studs on the passenger side. I just had both replaced at that point.
richs fishes
Long Island, NY
Definitely need to do some more investigating then! So your manifolds were leaking only when cold? About how long would they still be audible after startup?
About 30-40 seconds of very loud, after a minute start to quiet up. As it got worse it stayed louder even after warm up. When it’s just starting to go it’s more of a ticking until it heats up and the gasket seals.
Bill Schmidt
Bill Schmidt
Omaha, NE
Update.
I know some people said my engine sounded fine ... but I found a video on youtube from FordTechMacuLoco and on the the passenger side ticking sound. It sure sounded like my engine.
So I have a GREAT mechanic (Plug: Starky Auto, Omaha) Who for a couple hundred buck took off the passenger side cover and took the cam shaft out and inspected the roller followers and cam.
Result ... NO problem. It was super clean in the engine and no sludge which I feared. The roller followers (which can make the ticking sound) a few might have had some very slight bearing wear (very slight looseness) but no wear on the cam nor on the rollers.
In order to do that they need a timing belt holder which wedges down between the belts and only works if the timing belt tensioners are good. So they inspected that too and all good.
Very happy.
Side note looked like original cam phasers in the engine as well and they are in pretty good shape as well.
He took some pictures so I'll see if I can get them.
Ended up paying around $1200 all told because had him do some other work.
Front Differential rebuild, replaces some bearings which when driving sounded like dragging a cardboard box under the vehicle.
Fixed a O2 sensor which was giving me P2096 error check engine (Post Cat Fuel Trim System too lean Bank 1)
Fixed a broken vacuum line which was feeding the passenger front hub for 4x4 ... (don't know if this lead to more wear on the front differential bearings???)
Runs like a champ now and more importantly have the peace of mind of knowing exactly the state of the engine so I can get into the 300K+ club someday. :)
Thanks for all feedback.
Glad everything checked out. The passenger side top end is the last on the oil feed run so they generally run a tad louder on that side than the right side. This is demonstrated on both old 2 valves and newer 3 valves if you listen close. As long as it’s nottapping/knocking from under there you’re ok.
Bobmc
My new to me 2010 (145k) sounds like that as well, perhaps a little less loud. Started to worry a bit; I'll ignore it unless it gets worse.
Thanks for posting.
