Not ANOTHER Engine Noise Thread
N
Notrega
Tallahassee, FL
the boot just pulls off the coil
Well damn - The boot did not come out with the coil... I will have to pull the coil again and get the boot out... may just replace it because I had to tug hard to get the coil out. I imagine that it will tear...
N
Notrega
Tallahassee, FL
OK I'm not a patient guy... Drove it today and picked up a new boot, spring and some grease. I put it in and drove it around. The idle is better and almost all of the stutter is gone but what stutter IS there is harder if that makes sense. Also when I got into it hard it sounds like what I can only describe as quiet popping from the back of the engine.
It only threw the code twice - the CEL blinks but won't stay on...
I plan to drive it this week and the next. Before I tackle replacing the plug or messing with the injector.
Thoughts?
kb0jfg
Kansas
Thoughts?
You might check the plugs and make sure they are tightened to specs. If it sounds like a light exhaust leak I would check the plugs like I suggested. Just a thought.
