Odd sound after shutting off
bombutt71
Ft Drum, NY
Is there something in the fuel system that would cases a groaning sound to be made after shutting the motor off? It might last 10-20 secs and appears to be from the top of the motor. Thanks
Racenut
Deming, New Mexico
Is it only when you have been running the A/C? If so it is the rest of the pressurized liquid refredgerant flashing over to a low pressure gas. If this is the case you will hear it next to the fire wall mainly on the passanger side. In other words its normal. Just a thought.
B
bombutt71
Ft Drum, NY
Nope on both accounts. I don't have air ride and I haven't used the A/C or defrost for months. It is sometimes worse than others and have yet to figure out what I do differently.
Racenut
Deming, New Mexico
Have you done any mods (ie: CAI, K&N drop in, Gotts Mod)? Can you describe the sound a little more, Do you hear it mainly inside the truck or outside? Is it a metalic type of groaning?
B
bombutt71
Ft Drum, NY
The only mod is 1/2 a Gotts (just removed the silencer). The sound reminds me of some kind of pressure bleed down. I can't feel any vibration on anything I grab. Could it be some kind of fuel return? I couldn't get it to make the sound this morning but I was lucky enough to snap a rusty bolt off on the fog light.
Racenut
Deming, New Mexico
The fuel system typically retains it's pressure when shut off to aid in the next start and to keep from uneeded strain on the pump. It could be a vacumm bleed down. On the back of the Throttle body mount is where all of the main vacumm accesories attach (ie: brake booster, pcv, etc.) How long have you noticed the sound, or better yet could you hear it before you removed the silencer from the air box? With my CIA I always hear the vacumm bleed down now as where with the stock air box (unmodified) I could never hear it, sometimes it is loud and last a good bit others it is so short I bearly notice it. Are you having any drivability issues with it?
97_edition
PA
I agree with Racenut, I got the same noise after installing my CAI. Haven't figured out what is was but haven't experienced any problems either. Noise only last for about 10-15 seconds and just sounds like air releasing on top of the motor, depressurizing? Hope this helps.
B
bombutt71
Ft Drum, NY
I'm pretty sure it was there before I yanked out the silencer. I'm not too concerned. Thanks for the input. It'll wait until I get back from A-stan if at all.
joezek
psl, FL
Also check the hose and rubber seal going into your vacuum brake booster. If it's leaking, then you'll have a hissing sound for about 20 seconds after shut down depending on the size of the leak. The booster is like an acumulator and stores vacuum for your brakes.
