Odometer doesn't work after getting gas
ExplorerTom
Colorado
Each time I've filled up the truck, when I start the ignition the odometer is blank. Button doesn't seem to do anything either. Usually the next time I start the truck it works as normal. It hasn't blanked out during the many days while using the tank- just immediately after filling up.
Any ideas?
spt87a
Cape Cod
Have not seen this exact symptom myself, but these instrument clusters are known for bad solder joints to the LED display.
Easy fix except it will take a few minutes to get the cluster out.
Once out, trace the connection from the LED to the circuit board and then re-solder the connections. Here is a video I found on it:
2000 Ford Expedition Pickup Odometer Fix 5.4L Video
ExplorerTom
ExplorerTom
Colorado
thanks. And I've noticed it's not just when I get gas- just randomly.
I'm pretty handy with a soldering iron so I should be able to tackle this. Finding the time to do it will be the tough part.
Bedrck47
Elizebethtown, PA
I would love to know how YOU get the cluster out in just a FEW MINUTES
Bet its more like 30 to 45 minutes
Bowesmobile
Clarkston, Mi
Maybe the OP should stop "getting gas" on the odometer... It might work better if he didn't do that.
Yes, I think I'm funny!
bocco
Livermore, Ca
Raining all day yesterday and today in Northern Ca. Spent some time in the garage. Fixed the over head display and my odometer on my 2000 Expy.
Thanks to all that posted pics and made the videos.
ExplorerTom
ExplorerTom
Colorado
I did the resolder trick. It seemed to work- for awhile. Now it's back to randomly working. Maybe need to do it again but flow the solder a little better.
bocco
Livermore, Ca
Tom, I noticed my 2000 did the same thing the other day after I got gas. I touched my reset button, and it came back on. Mine also seems to go out after fueling. Wonder if touching the steel gas nozzle to the steel filler neck, has anything to do with it. Maybe a ground issue? Mine works more than not, so I don't mess with it for now.
ExplorerTom
ExplorerTom
Colorado
Mine comes and goes- no rhyme or reason that I can tell. If I tap just right on the clear plastic covering, most times it'll come back.
Sounds like my old 36 inch tube tv. Got it free years back, had a tech over to fix another tv. He banged on this one said $75.00 he soldered some wires/ circuits, been great for 5 years now. Just a heavy sob to move. Keep a flashlight in your truck, till you get energetic to fix. Maybe spring when it warms.
No members online now.
Landsbutter
