Off road exhaust (Manifold back)
kcobra
Ft. Lauderdale
Does anyone offer an off road exhaust that in effect eliminates the catalytic converter for a 2008 Expedition?
gixer2000
Retrofit or Bust
Massachusetts
Well you'd be looking for catless down pipes because the manifolds dont have the cats in them. You could just yave an exhaust shop cut them out and put in a piece of pipe though. However you will set a check engine light but I'm sure that could be turned off with a tuner
the bus
I did a full exhaust a year or 2 ago. I did not see a bolt in cheater pipe on the market. I ended up with a full walker system and 4 new oxygen sensors. Not sure how it will run without cats and o2 sensors not reading before and after readings. This Would Have To Happen AT A custom shop. Also if you need to pass a visual inspection test or a smog test not a great idea unless a true off road vehicle.
rjdelp7
2000 XLT
NY
2 of the 4 O2 sensors are feedback, for the PCM. The engine may run or may not even start, without them. If it runs it will be in cold start mode full time and use a ton of gas. The rear two are for emissions and give a CEL. without converters. The exhausts will get stupid, loud. I have heard it, on a newer 5.0l Mustang. Your engine actually requires back pressure and may pop or backfire(the Mustang did). I have seen guys Hollow out a conveter, but only pre 1996.
gixer2000
Retrofit or Bust
Massachusetts
Well front sensors need to stay but the rear can be removed and tuned out. All the rears do is monitor cat performance. The from report AFR to the pcm
Wali4vr
Colfax WI
Cool Jay.
But the only thing you have accomplished is to make a little noiser exhaust when you punch the accelerater. No hp or torque or any performance gain and no change in exhaust temperatures. But the tips look cool. Ya Hooo and yippee Kia Yia hay.
