off set leveling kit spacers
sdebusk
I have a 2011 Ford Expedition and I recently purchased the Heavy Metal 2" leveling kit which has the off-set spacers similar to the autospring kit, however my spacers are not marked for Driver or Passenger side. My question before I attempt to install is which way does the off-set need to go to be installed correctly. Does it need to set the strut more inward or outward. This may become obvious once I start but I was hoping someone my have had some experience with these off set spacers. Thanks in advance for anyone's suggestions.
S
sdebusk
I got the leveling kit installed and like I thought it became obvious once I started the install. They lifted the front of the truck 2" exactly and it looks great. So far the ride and the handling have not changed. It does look a little like the rear is lower than the front by looking at the wheel wells but I measured from the ground to the bottom of the running boards at the front and at the rear and they both measured the same at 13".
S
sdebusk
I added some pics to my profile. I'm located in South West Virginia near Bristol Motor Speedway!
