Ok to use this fluid in my transfer case
AZ59apacheguy
Fountain Hills AZ
Getting ready to perform a fluid swap in my transfer case. Just want to make sure I am using the correct fluid. I bought this at The auto parts store:
I only ask because it says nothing about Mercon V, only Mercon. I belive the old Ford part number for the transfer case fluid was XL-12?
Am I correct, can I use this fluid in my transfer case. Thanks
rtbrjason
Rochester, NY
It originally called for Mercon and in my manual it says specifically not to use Mercon V. Since Mercon V replaced the older Mercon though, I hear Ford is now saying it's okay to use.
I initially replaced mine with Dex/Merc fluid and my Tcase was getting stuck in 4x4 once it engaged. I switched to mobil 1 ATF but still ended up having to replace the Tcase last year. I filled the new (used part) one with Mobil 1 ATF and drove all winter without any 4x4 issues.
99WhiteC5Coupe
I would go to a Ford dealer part's department with your vehicle VIN and ask them to look up the correct fluid. You may pay a little more for the fluid there (than aftermarket) - but you will get the correct fluid and not have to worry.
A
AZ59apacheguy
Fountain Hills AZ
Went on youtube and found this video. In the video it clearly states that the correct part number for Ford Transfer Case Fluid was XL-12. Since the label on the Valvoline states that it is " Recommended for Ford XL-12 ", I should be good to go.
RonB1964
Olympia, WA
Also, the Motorcraft Mercon V bottle says not to use in the transfer case.
Im using Motorcraft Transfer Case fluid, XL12.
