whySKIPdodis
Hey everyone,
My 2007 Expy (5.4L V8, 231K miles, 6R75 transmission) recently started throwing P0741 (Torque Converter Clutch Solenoid performance/stuck off) and intermittently P0735 (gear 5 incorrect ratio). The truck has been shifting flawlessly until recently, but now goes into limp mode after driving for a bit - wrench light comes on, RPMs run high, and shifts are very sluggish. (I have read the available threads on this already: This one, and this one, and this one, and this one....but none of them get me what I need.
The Problem: I'm having trouble nailing down the exact part number for the TCC solenoid. From what I've read, it's accessible once the pan is off, but I'm getting conflicting information. Here's where it gets frustrating: I called both my local Ford dealer and Fischer Auto Parts, and they both told me the TCC solenoid only comes attached to the entire valve body assembly - which is clearly not ideal (or cheap!). But I've seen posts where people have replaced just the solenoid itself.
I've found lots of part numbers online, but I'm not confident which (if any) is the correct standalone TCC solenoid. I don't want to order the wrong part and end up with something I can't use. I think what I need is this, but I haven't taken mine out yet to confirm it has a brown cap or not: https://cobratransmission.com/6r60-...ord-lincoln-mercury-vehicles/?showHidden=true
My Plan: Since I have to drop the pan anyway to access the TCC solenoid, I'm planning to do a complete service while I'm down there:
Thanks in advance for any help!
Skip
- Replace TCC solenoid
- Change transmission fluid (already have a drain plug, and I'm a few thousand miles overdue anyway)
- New filter
- New pan gasket
- Can anyone confirm the TCC solenoid is available separately for the 2007 Expy, and if so, what's the correct part number?
- Has anyone successfully replaced just the solenoid without replacing the entire valve body?
- Is the TCC solenoid the likely culprit for these codes, or should I be looking at something else?
- Any tips for the job? Special tools needed?
- Anything else I should inspect/replace while the pan is off?
Skip
