jbanks
Hi all,
When I got this Navigator it had TERRIBLE IDLE and the CEL was on. The rear suspension was also down. I have done the Monroe conversion and some other suspension work.
Since the IDLE was so bad I checked the elbow on the back of the Manifold and it fell apart in my hand. So, I ordered the hose with PCV from Ford and replaced it. Never read the original codes though. I had disconnected toe battery to disconnect the Air suspension light so the codes were reset and I never saw what it was there.
With the new hose it ran TERRIFIC. Absolutely no idle problems or other drive-ability problems. Got my state inspection done and drove it about 500 miles. Then...wouldn't you know....I was leaving on a trip and the CEL came on, basically on the way out of the driveway. So...I went to Oreilly's and had them read the code. P0171. I thought no problem and went on my trip anyway. On the trip I used MAF cleaner to clean the MAF and some throttle body cleaner to clean up the throttle body.
The light has been on about 600 miles now. I went back to Oreilly's to see if there were any NEW codes but there are not. Still only P0171. I wanted Oreilly's to view the live data to check the fuel trims and I wanted to spray some carb cleaner into a vacuum line to check the O2 sensors but their scan tool Innova 3120 will not do live data
There is black smoke at the exhaust like it is running rich.
I have looked at most/all of the vacuum lines and don't see anything wrong.
I know someone with a better scan tool so I will try to go check that out
If I check the fuel trims and the O2 and come up with nothing...I think I am going to try to get the intake smoke tested.
I had also read it could be an exhaust leak near the first O2 sensor on bank one.
Anybody have any suggestions?
