P0171 & P0174
Rich_007
Tejas
2001 5.4 P0171 & P0174
These codes are keeping me from passing my inspection for reg renew. I can reset them and they show up as pending in about 30 miles and light the CEL after about 100 miles. Prob is if they show up as pending within 30-40 miles after a reset: computer says "not avail" to the inspection guy, even though the CEL isn't lit yet. Looked around for obvious vacuum leak and cant find any. Mechanic said he needs to smoke check it and go from there. Was just wondering if based on the pics from my OBD scanner if it points to anything particular. Had a fuel pump put in last year. Its an old wagon with over a quarter million miles on it. Was thinking since I got a good mechanic I trust and with that age, all the hoses etc... could be suspect, I would let him handle it instead of me shotgunning it and replacing all the hoses before I got done and still not find the problem. I am in an apartment, so I would have to do all the maint outside in the parking lot (which the mgmt would complain about). If I knew what it was, (anything short of ripping the intake off) I would do myself in the parking lot.121518 obd.jpg
Rich, we've got another member going through same deal. Smoking the intake is the best and fastest way to find your intake leak. In some cases it's just the rubber elbow coming off the pcv valve, but most of the time it's more involved. Your kinda limited living in the apartment. Your mechanic will more than likely find multiple hoses that are rotted and leaking, causing your intake leak. 17 years, and a bunch of heat, moisture, they get brittle.
Tonyray
Fallon, Nv
I see you replaced the pump last year. I would check for vacuum leaks. The PVC hose going to the Throttle body goes bad and is hard to see.
Petesexpy
Delaware
Same problem. turned out intake manifold gasket and $500... if both banks show lean, it's most likely a manifold gasket.
Rich_007
Rich_007
Tejas
Update: dropped it off at mechanic today. He will smoke the intake and see.
Hopefully I get an answer tomorrow. If its the intake (which it probably is), I will have to decide if I want to fix it or just keep the money and get another vehicle. The age and mileage have lowered my pain threshold how much I will spend on it.
Rich_007
Rich_007
Tejas
update: mechanic called and said he wanted to replace EGR and PCV. Said something about that's the only place smoke came out. Not exactly sure, I was sleeping when he called. I said do it. That was about 1:00 this afternoon and I haven't heard back yet. Hope he isn't shotgunning. Hopefully find out tomorrow.
If it was a cracked intake: the smoke test would have shown that, right??? keeping fingers crossed here.
Petesexpy
Delaware
Yes, smoke test would show intake manifold gasket. PCV likely means a leaky hoce. EGR is possible, but My bet is still on intake manifold gasket. Keep us posted.
Egr valve can be tested with a vacuum pump. He's covering his butt by changing egr valve and gasket. But who knows. Ask for old parts back, it's your right. Pcv valves rarely fail, occasionally they get stuck, but it's cheap enough. Make sure he changes all the hoses and elbows going up to the valve. You'll find out if that's all it was.
Petesexpy
Delaware
I agree. It's more likely vacuum hoses are leaking.
Rich_007
Rich_007
Tejas
Got it back yesterday. He said it needs to run a while to see if any codes show back up. He said they drove it about 20 miles I think. I drove to work and back (another 40 miles) no CEL light yet. I will put the scanner on it later and see if anything is pending. It sure is running a lot smoother. It was kind of surging and idling rough it actually stalled a few times on me before, so he plugged up some leaks with the new pcv and egr I guess. Another day will tell I think.
Petesexpy
Delaware
I'm sure it was a lot cheaper than the intake gasket....
Rich_007
Rich_007
Tejas
Passed the inspection. Yeeeeeeaaah Haaaaaaaaaaaaaaah... she will go another year (hopefully).
I was concerned because with the high mileage I was really on the fence whether I was going to sink a grand into it to replace the intake or not.
Petesexpy
Delaware
Intake gasket should be no more than $500
