P0302
Triple6locoz
Arlington
Hello I have my check engine light on its a p0302 I changed the spark plug and the coil but I stay have the code what else can it be?
99WhiteC5Coupe
To get exact help you should post the year, make, model and engine of your vehicle.
GaryH
Army
Are you sure you changed the #2 coil and plug?
T
Triple6locoz
Arlington
So you do think I should replace the second one on the other side I was wondering if it could be a fuel injector
99WhiteC5Coupe
If the check-engine light is not flashing, you could use Techron Fuel System cleaner (according to label directions) to see if it cleans the fuel injector.
k4vbb
Castle Rock, CO
Forscan is software that you can download for free to run the cylinder balance test. You'll need a Windows laptop and a cable to interface with the vehicle.
I recommend watching more of that guy's videos. He's extremely knowledgeable and has a TON of content on the 3.5 ecoboost engines.
