Passenger Front tire rubbing against lower control arm
Mernova
Orlando,FL
Hello all, Title says it all. Cant figure out why. When turning steering wheel all the way to right, tire rubs against lower control arm. Alignment was done. Check Ball Joints, all rods and bushings.
Anyone have any ideas?
Esat
US
What size tire and rims?
Sent from my SM-N960U1 using Tapatalk
1955moose
Did this rubbing start right after the alignment? Or has this been ongoing. You may have a stop in that side that's broken or missing. As the other poster said, what size tires are you running?
M
Mernova
Orlando,FL
Im running factory tires and rims. This has started happening after within the last 5k miles. So roughly 10K on the current alignment. Alignment was checked and all was OK.
Stops are a possibility, im also thinking possibly a bushing in the rack or the rack is off center. but am at a loss for seeing how rack could be/gotten off center
