99 Expedition
I have a 99 Eddie Bauer edition 4x4 Expedition. I started having trouble with the OD light blinking, and hard shifting. Had it tested and I was told it was the vehicle speed sensor (VSS) on the rear of the transmission. I replaced the VSS and for about 3 days it ran fine with no problems. Then the OD light started flashing again, hard shifting and the speedometer starting jumping around. This time I was told it was the ABS speed sensor on the rear differential. So I replaced it. Again it ran good for a few days then the problem came back. This time along with the flashing OD light and jumping speedometer, and the hard shifting cruise control stopped working properly. Had it tested and did a lot of research and came to the conclusion it was the solenoid pack in the transmission. So I changed the solenoid pack, new trans filter and fluid. Btw the transmission fluid was clean when I drained it out. This time it ran good for a couple weeks. Now when it's cold it will start off hard shifting, the OD light will start flashing sometimes but not every time. And seems to stop after it is driven for a few moments. But the speedometer is still jumping around, and the 4x4 light has started flashing. Cruise control is still not working properly. And most of the time if I stop and turn the engine off for a few moments then start it back up it runs fine. I'm not sure what it could be and would really appreciate any help I can get. I love my Expedition and just want to get it back to running as good as it use to.
