Please help with heated seat issues...
mstein86
Lonsdale, MN
So I'm trying to swap 99 heated seats into my 99 E.B. that has every option but heated seats. I'm trying to bench test them first and I've come across a few issues.
Bottom pad has continuity between the yellow wires but not the two blk/red stripe wires. There was this little diode or something in the heating pad so i removed it and tested the wires together and then I got continuity. What is that little round thing?
What wires powers the seat? I'm assuming the red/blk stripe wire in the plug with 3 wires. Black goes to ground but what about the wht/lt blue stripe wire? What dies it do?
So I put power to the red/blk and grounded the black wire and I get nothing. Any help would be appreciated.
[/IMG][/IMG][/IMG][/IMG]
M
mstein86
Lonsdale, MN
Tore both front seats a part. Drivers side needed a lower pad and module and the passenger side needs a module. Are these modules sensitive? My gf used the passenger side heater and it was on for maybe 20min during the ride to my sisters house. Left my sisters a few hours later and the heat doesn't work now. These seat are frustrating...
I'm getting used modules off e-bay. I cant stomach spending over $100 for a new one.
B
bedrck46
you may want to re-check you installation to see if anything came loose
M
mstein86
Lonsdale, MN
Went out and hit the heater button on the seat and it worked. I rechecked all the connectors and they seemed intact to me. I guess I'll wait until it stop working again.
Temple, Georgia
Did some reading on a F150 forum, they seem to think the seat module is also a timer with a preset value of 10 minutes. I'd suggest seeing if they cut off at a set time to verify. No one has posted a work around to change the amount of time. The other possibility is that the thermistor opens the circuit and resets after it cools off.
