Boostedbus
Yeah has an E4OD .... before the gear change it would drop all the way back in 2nd gear pulling hills while towing and run 65 mph in 2nd wound up tight to pull the hills, if I let it up shift to 3rd it would loose all it’s steam and look for 2nd to bail it back out. Not anymore with the 4.10’s but it still doesn’t come close to The towing guts of my 3.73 geared 3.5 Expy. That little engine truly does amaze me, it doesn’t even struggle a little bit even towing more of a load.Those 351 Windsors actually made decently good low end torque. Likely was the lackluster transmission in those years that was the problem not so much the motor. The old 4 speeds sapped a lot of power from it.
