Possible 1234yf Contamination during recharge
Solasta Pictures
Los Angeles
G’day team!
My aircon wasn’t cooling so I decided to do a top up myself.
I got three cans of RF-1234a from my local O’Rileys and rented their AC Gas diagnostic valves to do the top up. As this was my first time doing it, I watch some youtube videos and felt very confident. Until I had finished adding my three cans. I took off the connectors and noticed some green 1234yf on the low side input, when I vented the high side a combination of yf and 1234a gas emptied from the unit under pressure.
I’m assuming the person who rented the valves before me must have used yf and the shop had not purged or cleaned the valves after their return.
My question is, would the residual yf in the hoses and valves be enough to contaminate my system?
Thank you in advance for any advice.
Cheers
Cam
17expi
Mt Shasta Ca
G’day team!
Cheers
Cam
No, it won't hurt it. Some people are even going back to r134a from 1234yf and I'm sure there is 1234yf left in those systems. It's actually not much different but yf costs a lot more. You need to evacuate the system to return to 134 for those thinking about doing it.
jkayca
Ottawa, On
I would pull the system down to vacuum and replace the refrigerant as a precaution. The two types are not compatible and AC systems are expensive to replace.
17expi
Mt Shasta Ca
Nah, big waste of time and money. Call your local AC shop and you will see I am right.
