I been having a intermittent problem with the Power Steering Control Module. Some cool mornings it seems to fail on first start. This inturn causes a bunch of ABS & IPC codes. The fix has been to let the engine warm up a bit, then restart. Everything magically goes away. The problem is getting worse. I need to actually fix it. I suspect a bad connection. In this latest failure the PSCM doesn't even respond to Forscan.
1. Where is the Power Steering Control Module?
2. Is the a place on the harness or a connector that is typically the root cause.
2017 XLT 167K Miles
2017 XLT 167K Miles
