dlyoung1
Happy Friday! My wife's 2003 Expy has a small problem in the a/c that I need a little help with. When you set the a/c control to MAX, the air flow through the dash vents works just fine at idle, but as soon as you hit the throttle, the blend door eases closed and the air diverts to the defrost vents. Sounds like classic vac leak. But it's ONLY in the MAX/RECIRC position.
Found a vacuum diagram for the vehicle and it shows the recirc door actuator on its own "branch" off of the a/c control panel vacuum. I'm thinking there must be a leak/break/loose connector in that branch. Question: Where do I start looking for that recirc actuator?
Thanks!
Thanks!
