You’ve been waiting, panicked, searching for me, hanging in every minute to see if I’ll come back. LOL, you follow me everywhere like a pathetic lost dog. Get a life.
Fine to run 40, 42 or 44 whatever you like best....BUT let's make sure we specify that this is ONLY with tires that say max 44 (or higher) on the side.
NEVER put over 35 psi cold in a tire that says max inflation 35psi.
I don't check the air pressure in my tires 4 months. I might check them every 6 to 9 months but normally just when it gets cold because they always drop a couple of pounds or more. Newer good condition tires shouldn't be leaking any air and you shouldn't have to check them that often.Very true. I always check PSI and inflate when tires are cold/have not been driven - usually overnight. That does not happen often (inflating every week...), but have a cordless 120PSI air comp that both checks the PSI, inflates and stops when it gets to the PSI I specify. Very nice to have.
My tires do list 44 PSI as max. As mentioned I check once a week, along with fluid check. All seems well.
edit - meant to say thanks for the feedback. And side note, when I was a starving college student, I lived on used tires for my '85 Nissan Maxima, and drove the heck out of it.
Always new tires now when due....
I have A/T 285s on mine rates for 51psi and I run the max psi and the ride is wonderful not rough or anything!
I've tried different pressures. Now I keep it at the recommended pressure Ford says. Higher pressures work much better on the highways, but Metro New York roads are horrible. Higher pressures on the potholes rattle everything and beat the hell out of the front end.
I have no idea how people drive around with tires inflated like a basketball. I was in a rental the other day that for some reason was sitting at 42-43 psi on a 2018 Nissan Murano. It rode like absolute shit. I'd have stopped and dealt with it but was running behind as it was. Sure it got 32mpg on the hwy but I was literally sore from the drive after only couple hours.
It's amazing what a couple psi difference can make. Play around and see what you like. Every tire is different in how it responds at a given pressure as well as individuals personal taste in driving.
When I was in the tire shop last night a guy rolled in w a loaded 2018 F250, definitely not a tow vehicle, had 22''s and got some new Open Country AT tires and was like pump em up to 80, that's where it's at. No way this thing has ever seen anything other than pavement and didnt even have a ball on the hitch. I couldn't imagine how horrible the ride and road noise now is on a $65k vehicle.
Lots of things can affect gas mileage including temperature and even where the gas was purchased and different batches of gas from the same station but it is amazing sometimes how much a few pounds lower on the tires can suck the fuel mileage down. However, people will still argue and want to put very low inflation pressures due to the placards inside the door.Edit/Update: Today I took my first longer mileage trip - 80 miles RT. I believe the increase in PSI bumped my mpg avg up.
Since it was 95% freeway, I decided to reset the mpg avg. Wasn't really paying attn to it until on the way home. I ended up with 22.6 mpg. Not bad, and rides nice with the 42F/40R psi. Re: mpg, my area is relatively flat but used to get on fwy between 17 - 20 mpg. Can't believe it made a difference. Also did not repair, replace or change any parts with the old mpg vs new mpg.
