Putting 2007 bumper end back in place?
Gregg Eshelman
Idaho
Just a little bump popped the top of the bumper end loose ahead of the tail light. How big a job is it to get it back in place?
fuzzmanmatt
SUPER simple! Assuming you don't bend anything while pressing it back in place, it just snaps back in. I got a backup camera so I didn't have to do it again after the first two times.
G
Gregg Eshelman
Idaho
I've pushed on it but it's not popped back in.
fuzzmanmatt
There's little clips molded into the bumper cover that need to snap into the quarter panel. If they're damaged or bent it's not going to lock into place. You may have to actually remove the fasteners in the wheel well and pull the whole side out to see if they line up, and then slowly align everything again to get it to go together correctly.
G
Gregg Eshelman
Idaho
I took the light off so I could get a look down in there and I don't see anywhere it could clip into place. Looks like it might be something slightly bent, holding it forward. The plastic is cracked at the back corner just below the light.
Anyone have pics with the end off?
