Random symbols on message center 03 expedition
G
Germangsone
Do you know about a tutorial of how to remove the cluster and how long would it take to do it?
Temple, Georgia
Not meaning to sound like a smart azz but in electronics the only thing you look at is the packaging, everything else is verified by testing.
metaldrgn
somewhere
You would hope and something can go wrong in shipping.
Newport News, VA
two screws under the top of the dash...then pop the dash off...once u do that the cluster is held in with screws as well...should be plug and play from there
G
Germangsone
I removed the instrument cluster and opened it up and everything seems fine, I cleaned the connectors and put it back on and still doing the same thing. I think is time to hit the junkyards to see if I can find one.
G
Germangsone
I couldn't get to the circuit board because I didn't know how to remove the needles for the speedometer, gas, etc.. I didn't want to break them up
G
Germangsone
I looked at the soldered pins in the back of the cluster and they don't look loose or cracked, not sure how it looks on the other side because I couldn't remove the gauges panel
BIG GREEN FORD
loxahatchee Florida
If you do. Take a picture of your gages with your truck running so when u put it back together you turn it on and put the arms back in the right place
