olcoacher, look at your lower shock mounts in the rear. I bet you replaced your shocks about 5-7K miles ago. You can try tightening the lower mounts to "spot torque" (you know, tighten them till you see spots). But, in some cases, you have to get a slightly longer shim that slides in the center of the shock mount (replace the folded piece of metal piece that comes with the shock) to get the proper fit. The aftermarket people were given the wrong specs for the size of the metal tube that goes in the shocks. This results in the shock bolt not clamping down on the metal tube, leading ot movement over time.
A quick dive under the truck and then using your legs/arms to bounce the truck up and down a little as you watch the lower mounts is all it takes to verify your lower shock mounts are loose.
