Rear Seat Heat
bmonty9
Gig Harbor
My 2018 Expy Limited has rear heater seats but they stopped working. I’ve checked the fuses and the manual for a fix but came up empty so far. Does anyone have any suggestions or similar experiences?
Maxine the Max
South Dakota
The heating element might be burned out. That happened in my TaurusX. And it was a chore to replace it. I just went without. But that was the driver's seat that had more regular use. I can't imagine the back seat would get used as much.
Rob6805
Do the switches light up? And when you checked the fuse did you pull it and look closely? Also, I bet there is a relay in that circuit too.
bocabimmer
South Carolina
When I bought mine both elements were burned out. The light would come on for a second then just go off.
I’m not sure the sequence of events but the dealer claims they replaced one and the other was burned out too and that subsequently burned out the replaced one. So they ended up replacing both. (Under warranty thank goodness)
