Custom order from https://coilsprings.com/ They did amazing things for my 2010.I’ve got a 2017 EL 4x4. Looking for rear coil springs that offer a stiffer spring rate for towing. Has anybody found anything?
I didn’t realize I never responded. It’s a 37’ camper. I called coilsprings.com and I’m getting my coils tomorrow and 5100s Friday. I’ll post how it goes this weekendWhat are you towing?
In my case ford put 530ish lb spring rate rear springs so even with 860lbs of TW it dropped it 3” in the back. I swapped the 750lb spring rate this past weekend and it made a world of difference. Better control of the extra sway from the independent rear and still a comfortable and planted ride. As for the 5100s. My stock rear shocks are approximately 60mm in diameter. If I remember correctly the 5100s are 46mm so beating or cutting off my factory spring seats wouldn’t work. Does anyone know of any spring seats or perches for the 46mm bilstiens that will work?Good luck. Make sure you keep the tongue and axle loads within the limits. Usually when people complain about the rear sagging it is because they aren't moving enough weight back to the front axle.
