Rear strut replacement
sam21black
Louisiana
I am replacing the rear struts on my 2008 King Ranch El Expedition. I was wondering if anyone knew what size wrench or socket I need for the lower bolt of the strut. I know it's at least a 1" or bigger, but not a hundred percent sure the exact size. I do not have air suspension. Thank you.
B
bedrck46
get out your tape measure and measure across the flats. then go to Lowes or Home Depot or wherever you buy tools and get the right wrench/socket. That way you will be 100% sure you get the right tool. Its most likely metric
S
sam21black
Louisiana
I'm going to do that, but I thought someone might know the exact size.
Sent from my SCH-I535 using Tapatalk
B
bedrck46
That way you will be 100% sure that YOU have the right size.
Just in case someone were to give you the wrong information
Stoned06
Milwaukee
I believe the 2nd gens are 30mm, but not 100% sure if they carried that over to the 3rd gens.
S
sam21black
Louisiana
I measured and it is 30mm, and I'll let you know for sure in a little bit.
B
bedrck46
sounds like a somewhat good guess Your not sure!
That is why I suggested that he measure it so there is no guess work involved. He will get more satisfaction from finding the answer for himself than someone else taking a guess. And that way if you are wrong and he goes and buys a tool that doesn't fit he will be pissed at you. I never give answers to someone asking for that kind of information when they are capable of doing it themselves. \
So many come on this site for the first time asking for information that they can get for themselves.
S
sam21black
Louisiana
Like I said, it is a 30mm nut, but I used a 1-3/16" deep socket instead. I couldn't find a 30mm deep socket. The standard one worked just fine though. Thanks for the suggestions.
Stoned06
Milwaukee
Yep, pretty good guess on my part!!
B
bedrck46
lucky guess being your guess was for a 2nd gen and his was a 3rd gen you would have felt like a fool if ford had made a change but my reply to him was to measure it and he would know for certain which is what he did therefore no guess was needed
