peterwells
- Joined
- May 13, 2005
- Posts
- 35
- Reaction score
- 22
Hi,
This forum has helped me with a number of issues so I figured time to give a little back. if anyone has definitive torque values I'd appreciate it.
Car in question is a 2008 EL with 175kmiles, the symptoms are some shaking at speed and doesn't track well on poor road surfaces, wheels are balanced and tires are new. I looked through the front end and didn't see anything wrong so took it for a check up and they showed that the rear ball joints (on lower control arms) and rear stabilizer bushings and links were worn. I purchased Motorcraft parts (~$180).
I'm posting this because the online instructions I found made this job look a lot more difficult than it is, they show removing the hub which is not necessary, in fact the job is quite straightforward just remove the lower control arm (LCA) and press in a new ball joint. The shop wanted around $350 in labor, I took my time and recon it's a five hour job to do both sides.
Key points…
(i) I rented (loaned) the first three tools below and included the torque wrench for reference, all from AutoZone…
(a) Ball joint press - https://www.autozone.com/loan-a-too...int-and-u-joint-press-set-23-piece/449947_0_0
(b) Tie rod end separator set - https://www.autozone.com/loan-a-too...werbuilt-tie-rod-end-separator-set/449957_0_0
(c) Axel nut socket set - https://www.autozone.com/loan-a-too...-point-axle-nut-socket-set-8-piece/787749_0_0
(d) Torque wrench - https://www.autozone.com/loan-a-too...2in-drive-adjustable-torque-wrench/555599_0_0
(ii) The suspension bolts are tight, 250+ ft lbs, so you'll need extensions, breaker bar, etc
(iii) The weight of the car has to be on the suspension before torqueing the LCA bolts, given that I didn't have a lift I measured the position of the hub center when loaded and used the jack to lift the arm before torqueing (there are pictures below).
(iv) The car is in Houston and there was not a lot of corrosion, things came apart pretty easily.
Details…
Key points…
Details…
- With the car sat on the ground measure the distance from wheel arch to the center of the hub (in my case it was 20.5"), you're going to need that to load up the suspension before torqueing the LCA bolts later on. Note the wheel center cap is removed in the photo but there's no need to do that.
- Remove wheel, I also removed the brake caliper to replace the pads
- Remove the nut from the ball joint stud that goes through the hub, separate ball joint with fork (mine took some pounding but nothing extreme)
