whtbronco
My passenger side rocker panel rusted out. I intended to replace it October 2023, but it got put off due to an accident and vibration issues. Now it's finally back to the top of the list. I got started today and found what appears to be a support bracket that goes from the B pillar to the rocker panel. It was a fairly thick piece of U shaped sheet metal, compared to the exterior sheet metal at least. Well it's completed rusted through, heck a good portion of it is completely gone. The question is do I need to rebuild/replace that, it just doesn't seem like it's very important since it clearly has not been connected for a couple years. In fact this bracket allowed dirt to build up inside the rocker causing all the rust. Had I known that was inside rocker panel I'd have washed it out better and will in the future. Kinda sucks that I do actually wash out the rocker panels a couple times a year, but with all the dirt there I didn't do enough.
If I do replace it I can weld it up top before I put the new rocker panel on. I think I'd have to drill holes in the rocker panel to weld the bracket/brace to the rocker.
