RES sound lag
ExpyWeave
Hello! The Ford factory installed RES is not easy to use! Having multiple sound issues, but the main one is that when you pair the RES to Ford Bluetooth, to play using the speaker system, there is a significant sound mismatch. Anyone found solution for this? Thanks
18ExpyPlat
Maryland
Yes also had that issue. While you are playing the content on the screen, hit the bottom right button on the remote to bring up the on-screen options. Then scroll to Bluetooth and play with the lip-sync adjustment.
E
ExpyWeave
Thank you! I found where you can adjust the lip sync adjustment- what number did you set it to? I tried a few different number settings, and selected "save" but every time changes were not saved, lip sync adjustment was back to 0. Did you encounter this?
18ExpyPlat
Maryland
Are you saying it reverted back immediately or after turning the car off? I didn't have an issue with it saving but I don't think I've used it again since I adjusted it. I'll look and confirm and get the number. I think it was like 900 or something.
Dmowry
Ohio
Same thing is happening to me. Adjust the delay ms, hit save, and exit. Going back into settings its back to "0"
Matthew Abrams
Washington, DC
did you all order your units with RSE? i couldnt find find any with it already added and am now trying to look at my options. also, was it worth the hefty price point in your opinions?
