TXFRDOwner
@Johnathan M
Here's the OEM Wiring Diagram:
Here's the same diagram that I modified to get what you want accomplished:
1) Tap into the Blue/Gray wire Park Lamp - run a split wire to pin 85 & pin 87
2) Cut the fog lamp wire behind the headlamp switch - Connect the end hanging from the switch to pin 87A, Connect the other end (harness side) to pin 30.
3) Find a 12V wire source that is hot in start or run, wire a on-off rocker switch inline - and hook it up to pin 86
With this setup you can still use the OEM Fog switch. When you turn the park lamps on, the fogs won't come on automatically but the extra switch you add will allow you to turn them on/off w/ park lamps.
