TobyU - do you recall the brand of your slide-on ones? I don't anticipate the engine or tranny holding out long enough to make expensive body work worth it.
Yes, definitely read some reviews about them because you don't want the ones that are just thin aluminum that goes behind your gutters on your house. Does would be better than nothing and look okay but you really want something stronger and better corrugated to fit right over your existing ones. Then, whether you use adhesive, rivets, and some people even use screws to hold them on. Doesn't matter as much if they're fairly sturdy and fit properly.Some are just window-capping aluminum coil bent in a brake, installed with Liquid Nails.
