dakotazeb
I would like to remove the crossbars from the roof rack on my 2013 Expedition but can't seem to figure out how to get them off. Can someone please give me some help? Thanks.
There were some threads a while back about removing the roof rack completely. Pop a lid and back screws out at the four corners I think.
Like the man said, you might have to unscrew and at minimum loosen at least one of the side pieces to remove the cross pieces. Does it look that way on your Expy? I don’t know if they’re captured in there or not. I know on mine you can loosen the cross pieces and slide them forward or rear. I’d go out and look if I was within 1000 miles of mine. Maybe when I get home at 1am I can check.I don't want to completely remove the whole roof rack. I just want to take off the crossbars.
I moved mine several times due to the roof 'oil canning' when travelling 40-50 mph. I guess its the shape of the bar that acts like a wing and causes enough of a pressure delta on the roof panel to pull it up and down, making the 'booming' sound. I finally found a sweet spot."All of our Expys with cross bars were taken off the first day home from the dealerships."
Just curious, to try to make it more quiet, better mpg,?
Same here. For one, I believe it looks way better without them. And two, much easier for snow removal.
