rough idle
46L281GT
KY
So I've had the truck for a few months and i'm loving it as a daily driver. The issue I'm running to is it has a slight rough idle (nothing too terrible) with A/C on or off, only when at temperature. I have replaced spark plugs (not COP). I also do not have any soft of CEL I also checked for codes and no luck there either.
The other issue that I'm having is that when I try to start it after driving it that day it takes a while to actually start. probably 5-7 seconds of cranking. When it finally does start, it idles at around 200 trying to die for about 2 seconds then it's fine. I have replaced the fuel filter and no change. WOT is fine, cruising is fine. Any ideas for either of these issues?
Funugy
Frisco TX
You may want to try replacing or cleaning the MAF Sensor. If this thing gets dirty it can throw off the fuel/air mixture. Easy to do.
46L281GT
KY
Forgot to mention that i had done that as well
46L281GT
KY
2004 5.4 so it's the 2v. I will check for vacuum leaks and report back
1997SCEBFEX
Northwest Panhandle
are you hearing the fuel pump energize in addition to all the other work you've done?
any chance you have crud (ethanol-related) built up in the tank?
46L281GT
KY
Yes I can hear it priming when key is on. I don't think it has any debris but I've only owned it 4 months. It has 119000 miles
