Sealed or vented sub box?
Newport News, VA
i cant do bandpass at this moment cause i still use the space for luggage...and one of my kids sit in the back during long trips...
DR3W
DR3W
L.A. - IE/SoCal
Would basic plywood at like home depot or lowes be okay?
And where could i find carpet to wrap it in?
panda24619
San Diego
no ply wood sucks for boxes. do not use. use MDF. 1/2 is good for smaller boxes. but 3/4 is ideal. and you have 2 12s and they dont need a big ass box. so i think 1/2 would work out for you. dont even bother about carpeting it right now. that can be done later on. or even just fiber glass it and paint it to match your paint color.
Thermo
technical advisor
3/4" MDF or the like. The amount of additional space the 3/4" MDF takes over 1/2" is very minimal and any flexing in the box will distort the sound (when the board flexes back, it pushes on the speaker, this will distort the sound). As for carpetting to put on the box, check out any upholstery shop in the area, they should be able to sell you some carpetting for cheap. For around $100, you can probably have them do the job for you. The carpetting is cheap.
tallsville
LA
home depot lowes etc mdf( Medium-density fibreboard also known as Melamine) shouldn't be too expensive its what most home building products are made with.
ExpyPlowGuy
+1! It's pretty cheap, I think last time I built a box it was 20-25 bucks for a 4x8 sheet. And I generally had someone there cut up the sheet for me to my specs so I didn't have to do much cutting at home. They used to give you 4 or 5 cuts for free.
panda24619
San Diego
sometimes they dont do shit! it ****** me off. what ever. its not that hard to cut straight. just measure it like 10 times then cut once and sand down that edge to make it smooth. haha
Newport News, VA
they'll cut the angles on the ends too for wedges? i may build a box then...wood screws...wood glue...i cant cut the holes out though...darn
Thermo
technical advisor
DR3W, MDF is essentially pressboard. That is all I use. ANy hardware store is going to have a 4x8 sheet of it for pretty cheap.
