1955moose
- Joined
- Nov 23, 2014
- Posts
- 5,981
- Reaction score
- 1,338
I thought it was part of the new pump? Or is yours somewhere else?
Perhaps my pressures?? My running fuel pressure is at 88psi .... Still not sure what the deal is but she's running well, so I'm leaving it be for now.Sorry Tony got you mixed up with one of the others that was running at 68 psi. Yours was at 22psi, sorry for the mix-up.
Your the one Bain, confused you with Tony. I wouldn't run that high, it's like running around with high blood pressure, you got to get that pressure under control. If something blows, it could be catastrophic, like fire that you can't put out. At the very least please keep 2 ABC type fire extinguishers with you. Your running wide open, surprised your not fouling spark plugs. It's like having an alternator with no voltage regulator to keep voltage under 15 volts.
Great work Tony! Do you have to drop the tank again to reach the sender?Got everything back together fired right up and runs great only thing is sending unit not working so I drove down to the gas station put 20.00 in it and still on empty. To tired to do any more tonight will check the plug to make sure it's plugged in all the way tomorrow still have the old pump I guess if I have to take the new pump off and put it on the old tree.
