Tonyray
I have a 2000 Expedition 5.4 Eddie Bauer and the Service engine soon light came on I check the code and it's P0171 and P0174. I understand it's a bank 1 & 2 lean. I have replaced the PVC and hose. I though it must be what's wrong because it was taped all the way with black tape. So I put a new one on but still get the same code. I have cleaned the mass air flow sensor looked at all the vacuum hoses even replaced the fuel filter but I still get the same codes. Now it's getting hard to start and when you give it a little throttle it will try and die before it does rev the engine. So I'm thinking it might be a fuel pump issue. I'm going to get a fuel pressure gauge at Autozone tomorrow and see what the pressure is. Also going to buy a smoker tester to see if it's a vacuum leak.
