Side vent window "fell out", Where to buy replacement ?
Lee_H
Central New Jersey
Hello folks, Had an unexpected problem. Driver side rear window became unglued at the hinge. Had no idea this happened. Had a funny rattle while driving at slow speeds around town, pulled into a parking lot to see what was loose. Thought the side window was half closed, decided to open and close again. Glass immediately fell to the ground and broke into little pieces. Used gloves and a snow brush I had left in the truck to put the pieces into a part box I've been meaning to throw out (it had the old radiator fan clutch). I've seen some u-tube video on replacing the window on a Excursion (nothing with this body style Expedition). It looks like the whole assembly must be replaced. Looked at RockAuto and Amazon, no luck there. Please let this be a third party replacement part and not a dealer only thing. As an assembly I'm going to be charged a small fortune if it is from the dealer. This type of part is going to be destroyed if I try to get a salvage yard part, It does not look easy to remove. Kind of rip the thing out, clean and carefully put the new one in. Also - any other landmines I should look out for while replacing? Any help would be appreciated in locating a reasonably priced replacement part.KIMG0485b.jpg KIMG0488b.jpg KIMG0492b.jpg KIMG0487.JPG
Plati
If it was me & my truck ... I would make one out of plywood or some other material. Don't need to see out of that window so opaque is ok. But that's because my BEATER is on it's last legs and I just want to milk it for whateveritsworth and not put any money into it unless I have to. YMMV
Other than that "how about a window glass company"?
Lee_H
Lee_H
Central New Jersey
If the most reasonable fix is to get a plain part of glass from a salvage yard I would need to know what glue to use (normal epoxy is not going to do it nor Black Max superglue).
The old one is "cleanly" off the two metal flexing hinges so no clue there. Next is the other end which needs a snap on ball joint end to attach to the gearmotor. Mine broke in two as it fell. So no luck there either. Adding the glass is far easier than ripping apart the interior to rip the frame out as well. Still no idea where the whole assembly is unless it is a dealer only part. Car-Part. com does not have a window or glass section, I'll have to do this the hard way and email the local yards to get pricing and availability. As far as the homemade solution I would like to try and have the truck to look like it wasn't broken. Plywood is cheap, perhaps a clear plastic from HD or Lws that is bolted on would be a last resort spray painted with tint to match.
Hamfisted
Ft Lauderdale
You can probably call an auto glass repair shop in your area and they'll install it with the correct "glue" if you bring them a good glass panel to work with. Or send a message to that yard there on eBay and tell them you need the whole panel and hinge assembly intact.
Lee_H
Lee_H
Central New Jersey
Update, did not find a window yet. Will call and look in nearby part yards this weekend. Has anyone had experience with 50ml cartridge epoxy that looks like the squeeze things in hardware stores but need a mixing nozzle and special feed gadget or caulking gun adapter? The adhesive I'm looking at is Loctite E-20HP industrial epoxy. It can be had at Amazon or Grainger, looks good for glass and kind of thick to stay in place. Just wondering any good or bad with working with the stuff.
Hamfisted
Ft Lauderdale
That is more of a "crafts" epoxy than a "glass" epoxy. I wouldn't recommend it on glass. Generally glass adhesives are of the polyurethane family of adhesives. Hopefully you can get the entire glass and hinge unit altogether from your local yards. But if you DO end up trying to adhere the glass to the hinge mounts I would at least call a local auto glass shop and get their recommendations for a bonding adhesive for your purpose. But it's gonna take something like JB Weld epoxy or one of the other high psi strength polyurethane epoxies. There is a lot of leveraged weight on those mounts. Best to remove the hinge assembly and clamp it all together on a work bench for a few days to cure. I gave you a eBay link in a post above to the whole assembly for a hundred bucks. Seems pretty easy to me.
https://www.amazon.com/dp/B009EU5ZM0?tag=tools1st-20&linkCode=ogi&th=1&psc=1
Lee_H
Lee_H
Central New Jersey
I had bad experiences with eBay, I'll only spending an amount of money I'm willing to lose. Now, times are such I'm not willing to lose a hundred bucks. I'll live without the window until I see what I'm buying first hand.
The Loctite adhesive is an industrial product, I would look at this stuff for machine repair work. Most of the adhesives/ sealer for windshields (body shops) are meant for sealing first and holding second. Common store bought epoxies I would not trust in this application. Mostly I wanted to know how much waste in the mixing nozzle, how well does it mix and assembly - disassembly time compared to the working time given.
I found on car-part dot com that the listing for the part is Quarter Glass or Quarter Window. No luck on this at Amazon or Rockauto, I've bought parts from both and managed getting the correct part in the past.
Plati
I still find to hard to believe you can't just go to an auto glass shop and say "can you please fix this" and get it done. The OP never said if that was done? Not sure why, trying to do it on the cheap?
Btw ... those 2 part syringe type epoxy dispensers simply meter the appropriate amount of each component ---> you still need to manually mix them. Epoxy needs a thorough mixing.
update** I see the mixing nozzle now, didnt before ... never knew they had that, still would mix by hand **
Lee_H
Lee_H
Central New Jersey
Over the weekend I went window shopping at the local Salvage yards, bought the window from one, it will be Tues. or Wed. to get it out of the truck. I'll let you know how that went Thurs. or Fri.
The idea of a mixing nozzle on the epoxy is to do just that mix. How well it mixes is another question. If folks had made use of this setup (if it becomes necessary, there is still a chance the Salvage yard will remove the whole window frame and all) I would like to know how it worked.
If I was sitting on a pile of money I could "just go to an auto glass shop and say "can you please fix this" and get it done". No pile of money - no can do.
This is where "Know how knowledge" is so valuable, once learned it can be used over and over again. Welcome to the school, it does take a little bit of time to ask but helping each other is how stuff gets done. How many go to U-tube to find out how to do something, it works because folks share. I got the door code because someone shared the technique of aiming a phone camera by the fuse box and clicking away until the factory sticker could be read. Is going to a Ford dealer and paying $$$ money for the same information better?
lbv150
Northeast
Glad my insurance plan on all our vehicles includes complete glass coverage and zero deductible on glass....so I don't have to worry about things like this....
Plati
thanks for the followup. yes, i figured you wanted to save ca$h. always good
on the mixing ... i've used those and the ones i've used don't mix, just meter quantities
it's shown on the video that goes with ad & includes a wooden mixing spoon. update** I see the mixing nozzle now, didnt before ... never knew they had that, still would mix by hand **
would love to know more about the "aiming a phone camera by the fuse box and clicking away until the factory sticker". never heard of that ... any info?
Lee_H
Lee_H
Central New Jersey
OK, today (Wed.) I picked up the window. The Salvage Yard (T&E Auto Wreckers, Avenel, NJ) took out the whole window, frame and tossed in the motor as well. The close up is what failed on the vehicle, the two glue spots just stop gripping the window. Now this weekend I'll have to start removing the plastic trim around the window and get the old frame out. Any advice on the clips, I usually try to work the trim piece with a small screwdriver but perhaps there is a better way or tool to use..???KIMG0516.JPG KIMG0511.JPG
riphip
Memphis, TN.
Get a nylon tool (spoon). Usually comes in a kit for removing clips, plugs, etc. Won't scrape the paint off the metal. Screw drivers are not for this purpose. Amazon or local Walmart or parts store. Usually very inexpensive
Plati
Yes ... something like this
https://www.walmart.com/ip/4-Pry-Ca...MIzrf61L7u6wIVE4bICh3ZUwmrEAQYAiABEgIzufD_BwE
the canadian border agents used something like that when they went through my Expy with a fine tooth comb on the way into canada. when they got done i asked them if they found my spare wallet and i wanted to make sure it was still there. kinda pissed the guy off, oops.
riphip
Memphis, TN.
"the canadian border agents used something like that when they went through my Expy with a fine tooth comb on the way into canada. when they got done i asked them if they found my spare wallet and i wanted to make sure it was still there. kinda pissed the guy off, oops."
:king:
ManUpOrShutUp
PA
Harbor Freight. There's one in Iselin.
https://www.harborfreight.com/nylon-pry-bar-installer-kit-4-pc-63594.html
20% off too. :p
https://go.harborfreight.com/coupons/2019/08/20-off-any-single-item-at-harbor-freight/
ManUpOrShutUp
PA
:king:
Who the heck smuggles items into Canada? And yet when we went into Canada we were at the gate for 45 minutes. Coming home they were like: "Anything to declare?" Us: "Nope." Them: "Welcome back!"
Lee_H
Lee_H
Central New Jersey
OK, here is the highlights of the window repair/ replacement. Opening up the interior so that the bad frame can be removed.KIMG0520.JPG KIMG0525.JPG KIMG0527.JPG KIMG0523.JPG
